21 years agoMultiple Clock
Hi everyone, I try to implement a system with multiple clock domains. The NIOS system run with 50 Mhz and some avalon components should run with 100 Mhz (DMA, FIFO, internal SRAM). SOPC Builder...
21 years agoHi there,
I had the same problem. Make sure you are running the service pack for 4.2. This fixes things. Good Luck.
