21 years agoMultiple Clock
Hi everyone, I try to implement a system with multiple clock domains. The NIOS system run with 50 Mhz and some avalon components should run with 100 Mhz (DMA, FIFO, internal SRAM). SOPC Builder...
21 years agoI found the problem during the sythesis. SOPC Builder creates for the clock domain crossing logic:
endofpacket_bus_pipe : dma_0_control_port_slave_X_cpu_data_master_bus_pipe port map( data_out (31 DOWNTO 1) => open, data_out (0 downto 0) => internal_slave_endofpacket, clk1 => slave_clk, clk2 => master_clk, data_in => std_logic_vector'("0000000000000000000000000000000") & (A_TOSTDLOGICVECTOR(master_endofpacket)), reset_clk1_n => slave_reset_n, reset_clk2_n => master_reset_n ); Quartus doen't like this line : data_out (0 downto 0) => internal_slave_endofpacket, after changing to data_out (0) => internal_slave_endofpacket, synthesis works without a problem, but modelsim show some other problems http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif @joelw: no I didn't try. But I will do.
