21 years agoMultiple Clock
Hi everyone, I try to implement a system with multiple clock domains. The NIOS system run with 50 Mhz and some avalon components should run with 100 Mhz (DMA, FIFO, internal SRAM). SOPC Builder...
21 years agoAdd SignalTap II to the list as well.
I used a seperate clock for a custom peripheral on a uKit board, it built and works fine. The periperhal clock was 1/3 slower than system. Both clocks originated from same PLL. Have you tried a faster clock for CPU and slower for other, just as a test?
