21 years agoMultiple-Clock Domain with 2 Nios?
Hello, I tried the new multiple-clock domain feature (Quartus 4.2, Nios1.1) with a Cyclone evaluation board. One Nios should boot from flash and run out of SDRAM, the other Nios should also b...
21 years agoYes, why shouldn' it possible that both Nios boot out of the same flash?
The reset address of the first one is flash+0 and the second one gets flash+0x100000. Here is the text of the flash programmer for the first nios system: # ! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd D:/temp/EvalBoard_Cyclone/MP3_Player/software/MP3_Player_eth_ide/Debug # Creating .flash file for the FPGA configuration $SOPC_KIT_NIOS2/bin/sof2flash --flash=U5 --offset=0x600000 --input=D:/temp/ EvalBoard_Cyclone/MP3_Player/MP3_Player.sof --output=MP3_Player. flash Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert D:/temp/Ev alBoard_Cyclone/MP3_Player/MP3_Player.sof MP3_Player.rbf Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Processing ended: Thu Jan 27 09:41:31 2005 Info: Elapsed time: 00:00:01 # Programming flash with the FPGA configuration $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=MP3_Player.flash --sof=$SOPC_ KIT_NIOS2/components/altera_nios_dev_board_cyclone_1c20/system/altera_nios_dev_b oard_cyclone_1c20.sof --cable='USB-Blaster [USB-0]' --base=0x00800000 27.01.2005 09:41:35 - (INFO) nios2-flash-programmer: Launching Quartus Programme r to download: D:/Altera/niosii_v11_build137d/components/altera_nios_dev_board_cyclone_1c2 0/system/altera_nios_dev_board_cyclone_1c20.sof Pre-Reading 434KBytes of data from U5: |----.----+----.----| ********************* (4.176 sec). Erasing 7 Sectors: |----.----+----.----| ********************* (4.607 sec). Writing 448KBytes : |----.----+----.----| ********************* (22.242 sec). Verifying 448KBytes of data: |----.----+----.----| ********************* (3.705 sec). 27.01.2005 09:42:18 - (INFO) nios2-flash-programmer: Success. Verified 448Kbytes written to U5. 27.01.2005 09:42:18 - (INFO) nios2-flash-programmer: Flash programming complete # Creating .flash file for the project $SOPC_KIT_NIOS2/bin/elf2flash --flash=U5 --base=0x01000000 --end=0x1800000 --res et=0x1000000 --input=MP3_Player_eth_ide.elf --output=ext_flash.flash --boot=$SOP C_KIT_NIOS2/components/altera_nios2/boot_loader_cfi.srec # Programming flash with the project $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=ext_flash.flash --sof=__NO_SO F_PLEASE__ --cable='USB-Blaster [USB-0]' --base=0x00800000 27.01.2005 09:42:20 - (INFO) nios2-flash-programmer: SOF-download skipped. Pre-Reading 163KBytes of data from U5: |----.----+----.----| ********************* (1.853 sec). Erasing 3 Sectors: |----.----+----.----| ********************* (2.093 sec). Writing 192KBytes : |----.----+----.----| ********************* (9.643 sec). Verifying 192KBytes of data: |----.----+----.----| ********************* (1.603 sec). 27.01.2005 09:42:38 - (INFO) nios2-flash-programmer: Success. Verified 192Kbytes written to U5. 27.01.2005 09:42:38 - (INFO) nios2-flash-programmer: Flash programming complete The error message came from Quartus and the source is a file generated by the SOPC-Builder itself, it has nothing to do with my own written code. If you want I can send you a very small Quartus project (SOPC-builder design with 2 PIOs and 1 user interface) that shows the error message.
