21 years agoMultiple-Clock Domain with 2 Nios?
Hello, I tried the new multiple-clock domain feature (Quartus 4.2, Nios1.1) with a Cyclone evaluation board. One Nios should boot from flash and run out of SDRAM, the other Nios should also b...
21 years agoI haven't seen those error message before, but re-reading your original post has made me curious. You say that both processors boot out of Flash. That would mean that each needs a bootloader (I don't think you will get two of them). Can you copy and paste the text from the flash programmer into the post. I'll take a look and see what's going on.
Back to that error message. Do you have a signal in your system that is usually a bus, but has been minimized to a single line? I have never tried to declare a std_logic_vector (0 downto 0) before but I thought that would be a perfectly valid statement (valid, but not clean coding). If I don't get back to you right away send another message since I happen to be working with the clock crossing features right now (before the weekend roles around and I start forgetting things http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif ).
