21 years agoMultiple-Clock Domain with 2 Nios?
Hello, I tried the new multiple-clock domain feature (Quartus 4.2, Nios1.1) with a Cyclone evaluation board. One Nios should boot from flash and run out of SDRAM, the other Nios should also b...
21 years agoHi BadOmen,
In the first one, Nios, SDRAM controller, timer, uart, some PIOs, some interface to user logic and access to the tri-state-bridge (for booting). In the second, Nios, uart, tri-state-bridge (with SRAM, Flash), some PIOs and also some interface to user logic. The only common interface is the tri-state-bridge (instruction and data). Why do you ask?
