15 years agomulticycle instruction FSM with nios and the done variable
I have been trying for weeks to figure out how the done variable works and it seems like it has no effect whatsoever on the program. Can anyone explain how it works. Here's an example i've bee...
15 years agooops, i posted the wrong version of the FSM code. the only diff is that i have done <= '0' in the n=1 case in state s0. The simulation also works as I expect it to, an image of it is included at the bottom. But if I run the code on a nios II core on the DE0 board, it doesn't work. The results are delayed as described above with the same code.
here's the good version of the code:
PROCESS (reset, clk)
BEGIN
if (reset = '1') then
state <= s0;
ELSIF (clk'EVENT AND clk = '1') THEN
CASE state IS
WHEN s0 =>
IF (start = '1' AND n = '0') THEN
io_148194546 <= dataa;
io_277277265 <= datab;
state <= s0;
done <= '1';
ELSIF (start = '1' AND n = '1') THEN
io_109970892 <= dataa;
io_19111827 <= datab;
state <= s1;
done <= '0';
ELSE
state <= s0;
done <= '1';
END IF;
WHEN s1 =>
result <= io_1298736395;
done <= '1';
state <= s0;
WHEN OTHERS =>
report "Invalid State";
END CASE;
END IF;
END PROCESS;
END behavior;
http://skiareatrailmaps.com/images/simulation.JPG
