15 years agomulticycle instruction FSM with nios and the done variable
I have been trying for weeks to figure out how the done variable works and it seems like it has no effect whatsoever on the program. Can anyone explain how it works. Here's an example i've bee...
15 years agoHere's the whole code. To summarize last post:
Have to do y = ci(1,x,y) twice to get the result. Otherwise I get the result from the alst operation.
-- Generated VHDL code to implement Custom Instructions
-- CREATED: Thu Dec 02 10:20:48 EST 2010
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
ENTITY CI_HARDWARE IS
PORT ( SIGNAL clk : IN STD_LOGIC;
SIGNAL reset : IN STD_LOGIC;
SIGNAL clk_en : IN STD_LOGIC;
SIGNAL start : IN STD_LOGIC;
SIGNAL done : OUT STD_LOGIC;
SIGNAL dataa : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL datab : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL result : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL n : IN STD_LOGIC
END CI_HARDWARE;
ARCHITECTURE behavior OF CI_HARDWARE IS
TYPE state_type is (s0,s1);
SIGNAL STATE : state_type;
SIGNAL io_148194546 : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL io_277277265 : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL io_109970892 : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL io_19111827 : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL io_1556901833 : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL io_1685984552 : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL io_1298736395 : STD_LOGIC_VECTOR(31 DOWNTO 0);
COMPONENT lpm_add_sub
GENERIC ( lpm_direction : STRING;
lpm_hint : STRING;
lpm_representation : STRING;
lpm_type : STRING;
lpm_width : NATURAL
PORT ( dataa : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
END COMPONENT;
COMPONENT lpm_mult
GENERIC ( lpm_hint : STRING;
lpm_type : STRING;
lpm_widtha : NATURAL;
lpm_widthb : NATURAL;
lpm_widthp : NATURAL
datab : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
END COMPONENT;
BEGIN
lpm_sub_0 : lpm_add_sub
GENERIC MAP ( lpm_direction => "SUB",
lpm_hint => "ONE_INPUT_IS_CONSTANT=NO, CIN_USED=NO",
lpm_representation => "SIGNED",
lpm_type => "LPM_ADD_SUB",
lpm_width => 32
PORT MAP (io_148194546, io_277277265, io_1556901833);
lpm_mul_0 : lpm_mult
GENERIC MAP ( lpm_hint => "MAXIMIZE_SPEED=5",
lpm_type => "LPM_MULT",
lpm_widtha => 16,
lpm_widthb => 16,
lpm_widthp => 32
PORT MAP (io_1685984552, io_1556901833, io_1298736395);
lpm_add_0 : lpm_add_sub
GENERIC MAP ( lpm_direction => "ADD",
lpm_width => 32
PORT MAP (io_109970892, io_19111827, io_1685984552);
PROCESS (reset, clk)
BEGIN
if (reset = '1') then
state <= s0;
ELSIF (clk'EVENT AND clk = '1') THEN
CASE state IS
WHEN s0 =>
IF (start = '1' AND n = '0') THEN
io_148194546 <= dataa;
io_277277265 <= datab;
state <= s0;
done <= '1';
ELSIF (start = '1' AND n = '1') THEN
io_109970892 <= dataa;
io_19111827 <= datab;
state <= s1;
done <= '1';
ELSE
state <= s0;
done <= '0';
END IF;
WHEN s1 =>
result <= io_1298736395;
done <= '1';
state <= s0;
WHEN OTHERS =>
report "Invalid State";
END CASE;
END IF;
END PROCESS;
END behavior;
