20 years agoMulticycle Custom Instructions
Hi, I want to implement a multi-cycle custom instruction and I have written a Verilog code for the same. However, I am not able to find any information on how I should assert the various input ...
20 years agoHey, Check out the link below.. Its got some useful stuff that not all that well explained in the User guide..
http://www.niosforum.com/pages/project_det...p_id=34&t_id=18 (http://www.niosforum.com/pages/project_details.php?p_id=34&t_id=18) Hope this helps! Cheers Sai --- Quote Start --- originally posted by farida_tabu+jun 1 2006, 03:08 am--><div class='quotetop'>quote (farida_tabu @ jun 1 2006, 03:08 am)</div>--- quote start ---
<!--quotebegin-saiprashanth@May 22 2006, 02:14 PM hi,
i want to implement a multi-cycle custom instruction and i have written a verilog code for the same. however, i am not able to find any information on how i should assert the various input signals (eg. start, clk_en, etc) from the nios ide. i.e i want to know how i should do this from the main function. i would appreciate if someone could tell me the syntax for asserting input signals to the custom instruction.
any help extended would be highly appreciated.
thanks
sai
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15493)
--- quote end ---
--- Quote End --- Hi sai, I am also working in custom instructions. I am a newbie to NIOS and verilog. Can you pls send some example custom instruction code, or snippets so that i will have get an idea about it. Any suggestions or help is welcome. Regards, Farida <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15749)</div> [/b] --- Quote End ---
