16 years agoMulticore boot out of epcs
Hi, I have a booting problem. I want to start 2 Nios cores out of the epcs. First CPU: Reset-Vector EPCS Exception-Vector SRAM Second CPU: Reset-Vector EPCS Exception-Vector Onchip...
16 years agoi tried to use the advanced boot copier with the onchip memory option but i have a problem with the tcl thats used for it
can someone explain me what that tcl script does and which line is for what reason? my error: INFO: Finished loading drivers from ensemble report. SCHWERWIEGEND: ErrorLogException: Tcl script "bootcopier_bsp_settings_boot_onchip.tcl " failed: Memory device is a null pointer SEVERE: nios2-bsp-create-settings failed. nios2-bsp-create-settings --settings settings.bsp --sopc Y:/V3/Quartus9_0/BOOT_ONCHIP/LUFU_Nios.sopcinfo --type hal --script bootcopier_bsp_settings_boot_onchip.t cl --cpu-name RT0 failed create-this-bsp failed i modified the script so that it should fit my project but it doesn't seem like i was successful.
