13 years agoMulti-processing using the array processing language Apl.
I am keen to use the array processing language Apl as nodes in a multi-processing network.
I first worked on this in the 1980s/1990s, with the Transputer, on a Helios computer. In the 80s I was hand-translating Apl to Basic and 6800 assembler, in the 90s to LabVIEW, and at the moment I am having to do it to VHDL. The aim is to make use of Tim Budd's aplc Apl to c translator, which in the 1990s I ported to SGIs and the Dec Alpha, as well as the lowly Atari TT. This has the advantage that in the 19980s/1990s I also added a minimum set of multi-tasking / multi-processor facilities (Julian Timestamp, pipe, spawn, and detailed I/O control) which I believe give it some of the capacity to form multiprocessing nodes : http://home.earthlink.net/~swsirlin/aplcc.html (http://home.earthlink.net/~swsirlin/aplcc.html) http://www.lab-tools.com/instrumentation/html/dod22.html A Pipe has two ends. Using APL in a multiprocess/multiprocessor environment. A proposal for a flexible but easy to use syntax. J.B. Webber. Apl Quad Quote 20, 1, 1-2, Sept 1989. http://doi.acm.org/10.1145/379199.379200 (The proposal and implementation of a software mechanism now used by IBM.) Now I have had some trouble in compiling the aplc run time library for the Altera devices, I seem to keep picking up more than one library definition for some functions. I regret to say that to get this library to compile I have had to turn off all the multi-tasking facilities, but for the moment simple code does run. I will have to dig and see what the problem is, because when I look at the library files, it all seems to be there. Anyway, for a very short test, of summing a vector : apl running in microapl's aplx : V ← ⍳ 9
⎕ ← V
1 2 3 4 5 6 7 8 9
S ← +/V
⎕ ← S
45 niosii : Translated to c and compiled and running on a DE1 : 1 2 3 4 5 6 7 8 9
45 Here is a simple set of matrix operations in a function "matrix": source in aplx: matrix
'A:'
A ← ⍳ 5
A
'B:'
B ← ⍳ 9
B
'C: inner product:'
C ← A ∘.× B
C
'T: transpose:'
T ← ⍉ C
T
'O: outer product (matrix multiply):'
O ← C +.× T
O
'S: solve matrix:'
S ← C ⌹ A
S
niosii "media" floating point soft processor, on a terassic de1 development board : A:
1 2 3 4 5
B:
1 2 3 4 5 6 7 8 9
C: inner product:
1 2 3 4 5 6 7 8 9
2 4 6 8 10 12 14 16 18
3 6 9 12 15 18 21 24 27
4 8 12 16 20 24 28 32 36
5 10 15 20 25 30 35 40 45
T: transpose:
1 2 3 4 5
2 4 6 8 10
3 6 9 12 15
4 8 12 16 20
5 10 15 20 25
6 12 18 24 30
7 14 21 28 35
8 16 24 32 40
9 18 27 36 45
285 570 855 1140 1425
570 1140 1710 2280 2850
855 1710 2565 3420 4275
1140 2280 3420 4560 5700
1425 2850 4275 5700 7125
S: solve matrix:
1 2 3 4 5 6 7 8 9 I am currently trying to get ./configure to work from inside Eclipse. Then look at communications. If anyone else is interested in joining such a project, please do contact me. Cheers, Beau WebberNo RepliesBe the first to reply
