20 years agoMTD support build wrong
hi hippo: when i add mtd support , there is the message(DE2 board ) : uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. setup_arch: No persistant network settings s...
20 years agoYou need to learn flash programmer before using mtd.
First, resize your cfi flash to 4M base addr 0 ,in sopc builder, and regenerate sof. Then enable epcs mtd and cfi mtd, in drivers/mtd/maps/ edit epcs_map.cstatic struct mtd_partition epcs_partitions =
.name = "sof_kernel",
.size = 0x200000,
.offset = 0x000000,
static const char *part_probes __initdata = {NULL}; edit altera.c static struct mtd_partition alteramap_partitions = {
.name = "romfs/jffs2",
.size = 0x400000,
.offset = 0x000000,
}; Rebuild kernel image from the start "make clean", "make linux_hwselect....".... Follow the wiki, http://nioswiki.jot.com/wikihome/operating...flashprogrammer (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/flashprogrammer) To program sof and zImage to your EPCS. And erase cfi flash.
