20 years agoMTD support build wrong
hi hippo: when i add mtd support , there is the message(DE2 board ) : uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. setup_arch: No persistant network settings s...
20 years agohi hippo:
I read wiki about DE2 (http://nioswiki.jot.com/wikihome/operating...flashprogrammer) and do as it says. But the booting message is also : uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. setup_arch: No persistant network settings signature at 008F0000 Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6484k/8192k RAM, 0k/0k ROM (1127k kernel code, 461k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) NET: Registered protocol family 16 JFFS2 version 2.2. © 2001-2003 Red Hat, Inc. NIOS serial driver version 0.0 ttyS0 (irq = 2) is a builtin NIOS UART Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart io scheduler noop registered io scheduler deadline registered dmfe_probe:eth0, 50000 Khz Nios <DM9000> eth0 I/O: 80900090, VID: 90000a46 ADDR: 00:07:ed:00:00:00 dmfe_probe:eth1, 50000 Khz Nios FPS-Tech EPCS MTD Driver (fps-tech.net) 16 Mbit EPCS Chip found cmdlinepart partition parsing not available RedBoot partition parsing not available Creating 2 MTD partitions on "Altera EPCS Flash": 0x00400000-0x00600000 : "small_part" mtd: partition "small_part" is out of reach -- disabled 0x00600000-0x00800000 : "big_part" mtd: partition "big_part" is out of reach -- disabled NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP established hash table entries: 512 (order: 0, 4096 bytes) TCP bind hash table entries: 512 (order: -1, 2048 bytes) TCP: Hash tables configured (established 512 bind 512) NET: Registered protocol family 17 Freeing unused kernel memory: 348k freed (0x128000 - 0x17e000) Kernel panic - not syncing: No init found. Try passing init= option to kernel. and the RBF (raw binary file) how to convert ? from which file to convert ? Thanks very much!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
