13 years agoMTD issue on the DE2-115
Hi Everyone,
Did anyone successfully running the uClinux and mount the mtd0 (8MB Flash memory) on the DE2-115? I tried to do the "flash_erase /dev/mtd0 0 3" and got error return message "No such device", then I realize it was never recognized from the bootup. I am sure I got my HDL wire correct and set it as a CFI flash component. output wire [22:0] fl_address_out, output wire [0:0] fl_read_n_out, output wire [0:0] fl_write_n_out, inout wire [7:0] fl_data_out, output wire [0:0] fl_chipselect_n_out, input wire fl_ready_busy_out, output wire fl_RST_N_out, output wire fl_writeprotect_n_out As for the kernel setting, I followed the same configuration from http://www.alterawiki.com/wiki/mtd The devicetree: ext_flash: flash@0x10000000 { compatible = "ALTR,cfi_flash-altera_generic_tristate_controller", "cfi-flash"; reg = < 0x10000000 0x00800000 >; bank-width = < 1 >; device-width = < 1 >; # address-cells = < 1 >; # size-cells = < 1 >; ext_flash@10000000 { reg = < 0x10000000 0x00000000 >; }; //end ext_flash@10000000 }; //end flash@0x10000000 (ext_flash) The system had been boot up from the jtag and test out the flash read/write capability until recently I wanted to use it as a storage device. :confused: I am suspecting it has to do with the device tree and it's driver since I had a simpler issue with the SPI for the SD Card before. I greatly appreciated if anyone can point me in to the right direction on this. Thanks.No RepliesBe the first to reply
