--- Quote Start ---
Hey, Robin!
The first time I put the system to work I had the same problem, but since it has been a couple of months since I solved it, I don't remember what is the exact solution. However, I can point out some situations so you can debug and see if it works with your design.
# 1 - Add the line "run bridge_enable_handoff;" in your u-boot and compile it again (and put the new u-boot in the sdcard). You can add this line right after the line "setenv bootimage zImage;". This way you can be sure the bridge is enabled.
# 2 - Since your HPS freezes, I'm sure# 1 won't be your problem. What I think it happens is that your software messes up with the bridge and the system halts (I ran to the same problem. After the DMA transfered one packet of data I would loose communication with the board). Check if your streaming interface allows "sop" and "eop". If it does, then you have to check on SignalTap if you are generating these signals correctly. It might be a software problem as well... how are you configuring the dispatchers? Paste the code here if u want me to take a look!
# 3 - Use SignalTap to see how your transfer starts and ends.
Also, I'm quite sure that you have to enable the bridge communication while booting the device. If you wanna do that, follow this tutorial:
https://rocketboards.org/foswiki/view/documentation/embeddedlinuxbeginnersguide Basically to compile an u-boot you will create a file called "boot.script"" and write this onto it (and other commands u want so you can modify your u-boot)
echo -- Programming FPGA --
fatload mmc 0:1 $fpgadata soc_system.rbf;fpga load 0 $fpgadata $filesize;run bridge_enable_handoff;echo -- Setting Env Variables --setenv fdtimage soc_system.dtb;setenv mmcroot /dev/mmcblk0p2;setenv mmcload 'mmc rescan;${mmcloadcmd} mmc 0:${mmcloadpart} ${loadaddr} ${bootimage};${mmcloadcmd} mmc 0:${mmcloadpart} ${fdtaddr} ${fdtimage};';setenv mmcboot 'setenv bootargs console=ttyS0,115200 root=${mmcroot} rw rootwait; bootz ${loadaddr} - ${fdtaddr}';run mmcload; run mmcboot;
And after doing the previous step you need to compile the script. You can do it by running this command:
mkimage -A arm -O linux -T script -C none -a 0 -e 0 -n "Boot Script Name" -d boot.script u-boot.scr
After that replace the u-boot.scr from your sdcard to the one you compiled.
Let me know if this helps or if you have doubts about anything else. Cheers.
Regards!
--- Quote End ---
Hello Marcio,
At this point, all major steps in the code resemble the CL project, found here:
https://support.criticallink.com/redmine/projects/mityarm-5cs/wiki/writing_to_hps_memory . The only difference with the CL project is that I give the FPGA only 200MB DDR-RAM and that the discriptor.length is 32*4 instead of 0xFFFFFFFF. However, since this
should be a working project, I do not think there would be an error there. You are always free to take a look though :)
I will try the things you said later today, thank you for your input! much appreciated!
KR,
Robin
