15 years agoMPU problems
I'm running Quartus 10.0 SP1 and have a system that is comprised of 1MB of off-board SRAM memory, 32MB of off-board FLASH (unused), and 196kbytes of on-chip memory. Further, I have several periphera...
13 years ago --- Quote Start --- You have remembered to allow access to the JTAG area? --- Quote End --- I've tried to reply in my sopcinfo project (see below) the same regions of the Altera project example (also the JTAG area). https://www.alteraforum.com/forum/attachment.php?attachmentid=7050 All my software project (.text, .bss, .heap, .stack, .rodata, .rwdata, .exception) is stored in sdram. Only .entry is in ext-flash. I've set the following limits for the MPU regions: void nios2_mpu_data_init() { Nios2MPURegion region[NIOS2_MPU_NUM_DATA_REGIONS]; unsigned int num_of_region = NIOS2_MPU_NUM_DATA_REGIONS; /* JTAG UART */ region[0].index = 0; region[0].base = 0x84822; // Byte Address 0x021208B0 (64bytes) region[0].mask = 0x84823; // Byte Address 0x021208B8 (64bytes) region[0].c = 0; region[0].perm = MPU_DATA_PERM_SUPER_RW_USER_RW; /* JTAG debug module */ region[1].index = 1; region[1].base = 0x84800; // Byte Address 0x02120000 (64bytes) region[1].mask = 0x84820; // Byte Address 0x02120800 (64bytes) region[1].c = 0; region[1].perm = MPU_DATA_PERM_SUPER_RW_USER_RW; /* SDRAM */ region[2].index = 2; region[2].base = 0x40000; // Byte Address 0x01000000 (64bytes) region[2].mask = 0x80000; // Byte Address 0x02000000 (64bytes) region[2].c = 0; region[2].perm = MPU_DATA_PERM_SUPER_RW_USER_RW; /* Entire address range */ region[3].index = 3; region[3].base = 0x0; // Byte Address 0x00000000 (64bytes) region[3].mask = 0x2000000; // Byte Address 0x80000000 (64bytes) region[3].c = 0; region[3].perm = MPU_DATA_PERM_SUPER_RW_USER_RW; nios2_mpu_load_region(region, num_of_region, 1); } void nios2_mpu_inst_init() { Nios2MPURegion region[NIOS2_MPU_NUM_INST_REGIONS]; unsigned int num_of_region = NIOS2_MPU_NUM_INST_REGIONS; /* JTAG debug module */ region[0].index = 0; region[0].base = 0x84800; // Byte Address 0x02120000 (64bytes) region[0].mask = 0x84820; // Byte Address 0x02120800 (64bytes) region[0].c = 0; region[0].perm = MPU_INST_PERM_SUPER_EXEC_USER_EXEC; /* SDRAM */ region[1].index = 1; region[1].base = 0x40000; // Byte Address 0x01000000 (64bytes) region[1].mask = 0x80000; // Byte Address 0x02000000 (64bytes) region[1].c = 0; region[1].perm = MPU_INST_PERM_SUPER_EXEC_USER_EXEC; /* Entire address range */ region[2].index = 2; region[2].base = 0x0; // Byte Address 0x00000000 (64bytes) region[2].mask = 0x2000000; // Byte Address 0x80000000 (64bytes) region[2].c = 0; region[2].perm = MPU_INST_PERM_SUPER_EXEC_USER_EXEC; nios2_mpu_load_region(region, num_of_region, 0); } When I run the code the exception handler executes and shows the Cause Symbol = 17 (NIOS_EXCEPTION_DATA_REGION_VIOLATION). Thanks a lot
