20 years agompeg2 decoder library
Tarek, please find,
http://nioswiki.jot.com/wikihome/operatingsystems/mpeg2dec (http://nioswiki.jot.com/wikihome/operatingsystems/mpeg2dec)2 Replies
Thanks .. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
i was willing much less.. your effort are extremely perfect... thannk you http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif - Altera_Forum
Moin,
Did anyone use that videodecoder in the last 2 years? I'm able to compile it and run it, but i don't get a proper decoded video at all. Here's the command line i use to decode (from a MPEG transport stream) on both a nios system and a PC: mpeg2dec -t 0x45 -v -o pgm /mnt/listra.mpg On the nios system i get also lots of decoded pictures, but all looking totally garbled. When i compile the same decoder with the native gcc on my PC and decode the same stream, the pictures look OK. Other Software is running perfect on the nios system; also no errors or suspicious warnings during compilation and decoding. Exactly the same problem with newer versions of mpeg2dec. Any idea, what's going wrong here? Cheers, WK
