20 years agoMoving filesystem into CF
Hi people,
What is the best way to go about populating the /dev directory in my compact flash file system? After mounting the CF card, the kernel panics:Kernel panic - not syncing: No init found. Try passing init= option to kernel I assume this is due to the fact that there is nothing in the /dev directory? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif Is there are more elegant way to populate /dev than manual entry? Thanks for your time. Cheers, Mark2 Replies
The easiest way is to generate a filesystem using the microtronix filesystem plugin for the Nios2 IDE.
Create an ext2 filesystem on your flash-card Mount the ramfs image. copy everything from the ramfs image to the flash card. This gives you a nice base system with all the needed apps (including init http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif ) and /dev entry's to start off with. - Altera_Forum
Thanks very much for your suggestion wgoossens.
I made the file below, chmod +x, then ran it. Anyone is welcome to use this to generate entries in /devmknod dev/button c 62 0 mknod dev/console c 5 1 mknod dev/cua0 c 5 64 mknod dev/cua1 c 5 65 mknod dev/cua2 c 5 66 mknod dev/cua3 c 5 67 mknod dev/cua4 c 5 68 mknod dev/cua5 c 5 69 mknod dev/cua6 c 5 70 mknod dev/cua7 c 5 71 mknod dev/cua8 c 5 72 mknod dev/cua9 c 5 73 mknod dev/fb0 c 29 0 mknod dev/fb1 c 29 32 mknod dev/hda b 3 0 mknod dev/hda1 b 3 1 mknod dev/hda2 b 3 2 mknod dev/hda3 b 3 3 mknod dev/hda4 b 3 4 mknod dev/hda5 b 3 5 mknod dev/hda6 b 3 6 mknod dev/hda7 b 3 7 mknod dev/hda8 b 3 8 mknod dev/hdb b 3 64 mknod dev/hdb1 b 3 65 mknod dev/hdb2 b 3 66 mknod dev/hdb3 b 3 67 mknod dev/hdb4 b 3 68 mknod dev/hdb5 b 3 69 mknod dev/hdb6 b 3 70 mknod dev/hdb7 b 3 71 mknod dev/hdb8 b 3 72 mknod dev/i2c-0 c 89 0 mknod dev/i2c-1 c 89 1 mknod dev/kmem c 1 2 mknod dev/mem c 1 1 mknod dev/null c 1 3 mknod dev/ptyp0 c 2 0 mknod dev/ptyp1 c 2 1 mknod dev/ptyp2 c 2 2 mknod dev/ptyp3 c 2 3 mknod dev/ptyp4 c 2 4 mknod dev/ptyp5 c 2 5 mknod dev/ptyp6 c 2 6 mknod dev/ptyp7 c 2 7 mknod dev/ptyp8 c 2 8 mknod dev/ptyp9 c 2 9 mknod dev/ptypa c 2 10 mknod dev/ptypb c 2 11 mknod dev/ptypc c 2 12 mknod dev/ptypd c 2 13 mknod dev/ptype c 2 14 mknod dev/ptypf c 2 15 mknod dev/ram0 b 1 0 mknod dev/ram1 b 1 1 mknod dev/ram2 b 1 2 mknod dev/ram3 b 1 3 mknod dev/spi c 60 0 mknod dev/tty c 5 0 mknod dev/tty0 c 4 0 mknod dev/tty1 c 4 1 mknod dev/tty2 c 4 2 mknod dev/tty3 c 4 3 mknod dev/tty4 c 4 4 mknod dev/tty5 c 4 5 mknod dev/tty6 c 4 6 mknod dev/tty7 c 4 7 mknod dev/tty8 c 4 8 mknod dev/tty9 c 4 9 mknod dev/ttyJ0 c 232 16 mknod dev/ttyS0 c 4 64 mknod dev/ttyS1 c 4 65 mknod dev/ttyS2 c 4 66 mknod dev/ttyS3 c 4 67 mknod dev/ttyS4 c 4 68 mknod dev/ttyS5 c 4 69 mknod dev/ttyS6 c 4 70 mknod dev/ttyS7 c 4 71 mknod dev/ttyS8 c 4 72 mknod dev/ttyS9 c 4 73 mknod dev/ttyp0 c 3 0 mknod dev/ttyp1 c 3 1 mknod dev/ttyp2 c 3 2 mknod dev/ttyp3 c 3 3 mknod dev/ttyp4 c 3 4 mknod dev/ttyp5 c 3 5 mknod dev/ttyp6 c 3 6 mknod dev/ttyp7 c 3 7 mknod dev/ttyp8 c 3 8 mknod dev/ttyp9 c 3 9 mknod dev/ttypa c 3 10 mknod dev/ttypb c 3 11 mknod dev/ttypc c 3 12 mknod dev/ttypd c 3 13 mknod dev/ttype c 3 14 mknod dev/ttypf c 3 15 mknod dev/zero c 1 5 mkdir dev/input mknod dev/input/event0 c 13 64 mknod dev/input/event1 c 13 65 mknod dev/input/js0 c 13 0 mknod dev/input/js1 c 13 1 mknod dev/input/keyboard c 10 150 mknod dev/input/mice c 13 63 mknod dev/input/mouse c 10 149 mknod dev/input/mouse0 c 13 32 mknod dev/input/mouse1 c 13 33 mknod dev/input/ttyACM0 c 166 0 mknod dev/input/ttyACM1 c 166 1
