21 years agoMounting usb flash stick
I am developing a USB IP core, and I am now at the stage where I am attempting to create a uClinux driver. With the new driver compiled into the kernel, and debug messages enabled, I see the f...
21 years ago# fdisk -l
/dev/ide/host0/bus0/target0/lun0:<6>check_part[0]=17241628:<6>res=0:<6>check_pa rt[1]=17248964: p1 res=1: Disk /dev/hda: 4 heads, 32 sectors, 246 cylinders Units = <7>usb-storage: queuecommand called cylinders of 128 * 512 bytes Device Boot Start End Blocks Id System /dev/hda1 1 246 15728 83 Linux Disk /dev/sda: 3 heads, 43 sectors, 1002 cylinders Units = cylinders of 129 * 512 bytes Disk /dev/sda doesn't contain a valid partition table#
