21 years agoMounting usb flash stick
I am developing a USB IP core, and I am now at the stage where I am attempting to create a uClinux driver. With the new driver compiled into the kernel, and debug messages enabled, I see the f...
21 years ago........
scsi0 : SCSI emulation for USB Mass Storage devices Vendor: F3D6368? Model: ?Fash Disk 1.6? Rev: !? Type: Direct-Access ANSI SCSI revision: 02 SCSI device sda: 129281 512-byte hdwr sectors (66 MB) sda: assuming Write Enabled sda: assuming drive cache: write through /dev/scsi/host0/bus0/target0/lun0:<6>check_part[0]=17241628:<7>usb-storage: que uecommand called res=0:<6>check_part[1]=17248964:<6>res=0: unknown partition table Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0 hi! i added sl811 to altera cyc board, and run uclinux . the"unknown partition table" have troubled me for a few days. do u know how to solve it??? thank u!!
