21 years agoMounting usb flash stick
I am developing a USB IP core, and I am now at the stage where I am attempting to create a uClinux driver. With the new driver compiled into the kernel, and debug messages enabled, I see the f...
21 years agoThanks marc, that helped.
It turned out that I also needed to add some nodes to the filesystem; @sda,b,8,0 @sda1,b,8,1 Hopefully I got this correct? So, now when I mount the USB partition I getmount -n -t vfat /dev/sda1 /mnt/usb
FAT: codepage cp437 not found
mount: wrong fs type, bad option, bad superblock on /dev/sda1,
or too many mounted file systems# What could cause "FAT: codepage cp437 not found" ? I believe that the formatting is correct; Disk /dev/sda: 65 MB, 65011712 bytes
2 heads, 62 sectors/track, 1024 cylinders
Units = cylinders of 124 * 512 = 63488 bytes
Device Boot Start End Blocks Id System
/dev/sda1 1 1024 63457 b Win95 FAT32
