MusGer
4 years agomount text file
Hi there;
It is possible to mount text file using normal run mode, nonetheless we can read write of text under debugging mode only ??
thanks in advance your contribution
Regards .
- EBERLAZARE_I_Intel
I am not sure what you are trying to achieve, is it copying the output to a text file (.txt)?
- MusGer
Thanks for ur respond,
I try to copy a chunk of enormous dataset that stored in host computer with extension (txt) file to complete computations using soft-processor.
I hope you get my point, and appreciate your support.
Here is the debugging steps:
I am unaware to mount to a .txt file that you are trying to achieve.
Maybe you could check this thread discussion a text file exports:
Could you check my previous respond?
