21 years agomount root over NFS
Over the last two days, I've been trying to get the NIOS kernel to mount its root FS over NFS, without result. I assume I'm missing something obvious, but I am missing it. The server (D...
21 years agoI has changed:
@console,c,5,1 ==> console @ttyJ0,c,232,16 ==> ttyJ0 Then the <div class='quotetop'>QUOTE </div> --- Quote Start --- Warning: unable to open an initial console.[/b] --- Quote End --- is fixed. New log: <div class='quotetop'>QUOTE </div> --- Quote Start --- Looking up port of RPC 100003/2 on 218.192.171.46 Looking up port of RPC 100005/1 on 218.192.171.46 VFS: Mounted root (nfs filesystem). Freeing unused kernel memory: 72k freed (0x1174000 - 0x1185000) Kernel panic - not syncing: No init found. Try passing init= option to kernel.[/b] --- Quote End --- Remaining the last error. I am sure /bin/init is bFlat excutable file. What's next ? Thanks. PS: My debug environment: ----------- 1. Copy target dir to NFS share dir 2. WinXP + x-WinPro 5.3 to start NFS server 3. Nios 5.0
