19 years agoMotion-JPEG decoder/encoder
Hi,everybody: I used Altera DE2 board and Web Camera. I will display image in IE through boa web server ( Motion-JPEG format) . but I don't know how to decoder/encoder images. Anyone can...
19 years ago --- Quote Start --- originally posted by hippo@Jan 9 2007, 10:34 AM there is a camserv in uclinux-dist.
you need to modify shared library usage in it.
the camserv should support a http interface, so you don't need boa.
are you using usb webcam? i don't think the usb on de2 is fast enough to support video in.
you should use composite video input or camera module through 40pins headers (terasic has it).
i haven't tried video input on de2 yet. i will try them later.
ps. i checked usb wlan on de2, i think it is the isp1362 hcd driver's problem.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20438)
--- quote end ---
--- Quote End --- hi, hippo Thank you very much for your reply. I used DE2's camera module through 40pins headers. I will use wireless to transmission images from DE2 board to PC. Is fast enough? Regards Faye
