20 years agoMoreThanIP Ethernet driver
I'm running into problems trying to compile the MoreThanIP ethernet driver into the uCLinux kernel. Has anyone else seen this? Is there a solution? CC arch/nios2nommu/kernel/setup.o ...
20 years agoLooks like you haven't selected the correct PTF file for your Kernel Project OR you haven't included the MoreThanIP component in Sopc Builder.
The messages you get are missing declarations in the system.h file which is generated from the ptf file.
