19 years agoMore Quartus source-control questions
Is there an easy way to separate user files from files generated by Quartus? We have some user .bdf and .v files and also some wizard-generated .v files in the Quartus project directory. SOPC Builder...
19 years agoI found a way to keep it very clean. I am using RCS, and I made a batch file to check out all the necessary files, and none of the extraneous files.
Basically, I make a new directory, and into it I check out: -All .vhd files I created -All .vhd files created by the MegaWizard -.ptf file -.qpf file -.qsf file -.cof file (you might not have one of these, I find it helpful in making .pof's) If you have custom components in your SOPC system it gets a little tricky. This thread was useful to me: http://forum.niosforum.com/forum/index.php...wtopic=5067&hl= (http://forum.niosforum.com/forum/index.php?showtopic=5067&hl=) Also, by default, files checked out are read only, so I have to change the permissions on some files. This system is also nice because I keep the version control repository on a network drive, which is backed up, and I check things out to my local drive, which is faster. Naturally, I have to update my batch file whenever I create new files, or stop using old files, but that's not too bad. -Brian
