12 years agoModifying SSS example to use SOCK_DGRAM
I made a trivial change today to the Simple Socket Server example that comes with the altera software. I changed the SOCK_STREAM to SOCK_DGRAM. Now the listen() fails for some reason, but errno is 0?? Code and output are below.
if ((fd_listen = socket(AF_INET, SOCK_DGRAM, 0)) < 0) {
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE," Socket creation failed");
addr.sin_family = AF_INET;
addr.sin_port = htons(30);
addr.sin_addr.s_addr = INADDR_ANY;
if ((bind(fd_listen,(struct sockaddr *)&addr,sizeof(addr))) < 0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE," Bind failed");
if ((listen(fd_listen,1)) < 0)
printf("errno = %d\n", errno);
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE," Listen failed");
Created "Nios II Simple Socket Server" task (Prio: 10) errno = 0 [Network]: See STDERR for expanded diagnosis translation. [Network]: [SSS_task] Listen failed [Network]: ERRNO: : [Network]: See STDERR (FAULT_LEVEL is SYSTEM). [Network]: FAULT_LEVEL is SYSTEM. [Network]: FATAL Error, Restart required. [Network]: Locking scheduler - endless loop. No free buffers for rx No free buffers for rx1 Reply
You cannot use listen or accept with message-oriented (=dgram) sockets.
They makes sense only with stream sockets which are connection-oriented
