15 years agoModifying EPCS bootloader
Skip to tl;dr at the bottom if so inclined. Background and such is there to cover some possible questions. background: (Developing in Q10.1) I am developing a project with two separate fir...
15 years agoThe nios code won't be position independant - that is only done for shared libraries.
However it could well be there to force the physical address be different from the logical address - this will affect the elf program headers. Typically the physical and logical addresses are different when the code will be copied after being loaded, or when the memory maps seen by the cpu and loader are different.
