15 years agoModifying EPCS bootloader
Skip to tl;dr at the bottom if so inclined. Background and such is there to cover some possible questions. background: (Developing in Q10.1) I am developing a project with two separate fir...
15 years agoFigures, I search for hours for a solution and finally ask for help and I make progress not 30 minutes later. :oops:
I am half way there (I hope). I managed to find the "make help" option when running in the nios2 command shell. This generated srec files. (I sort of expected that) Now I need to figure out which SREC file to use and to convert it into my hex file. The hardware I am using is an EPCS128 and a Cyclone IV. (should work the same as a Cyclone III)
