11 years agoModify/Add a new Function to existing BSP/HAL Driver
Can someone Help with the steps involved in modifying an existing bsp/HAL driver for Nios. I need to add few Features in the exiting driver. I cannot even add print statements as the "generate BS...
11 years agoHi, I've managed to do this. I've written a very basic Avalon-Memory-Mapped component with a few registers which I wanted to incorporate into a .qsys file and be seen by a Nios. Attached in the zip file is the component "avalonmm_regspace_vhdl.hdl" and the .tcl files required to incorporate it into the hardware " avalonmm_regspace_vhdl_hw.tcl" and then the software (ie. driver) "avalonmm_regspace_vhdl_sw.tcl". In Eclipse as long as when you generate your BSP it looks into the directory containing the ..._sw.tcl file it should incorporate the driver into a "driver" directory.
Hope this helps. Cindy
