11 years agoModified *.dts for custom driver to *.dtb conversion
Thanks in advance. I'm working with Quartus 14.1 and linux kernel 3.9.0 with the Altera SoC Cyclone V Dev Board and the Golden Design. I've successfully created a new project that has added a pl...
11 years ago --- Quote Start --- I'm saying that going from the binary .dtb file to a text .dts file is buggy. Or was at one time. I don't know the current state. I use quartus 14.1.1 and it has dtc. Are you running it from the EDS command shell? It won't work from the NIOS command shell. --- Quote End --- I got a .dtb file from my .dts file but it hangs at: Starting kernel So taking your suggestion of starting with a good known .dts file I'm hoping that there is one in the GSRD files (I'm not at that computer right now). I did learn something about Qsys and generating the *.sopcinfo with the proper information for your new IP. Adding Device Tree Generation Support to an IP Block at http://www.rocketboards.org/foswiki/documentation/devicetreegenerator131#adding_device_tree_generation_support_to_an_ip_block you can add to the .tcl file for that IP and generate what you need so the sopc2dts conversion has all the information it needs.
