12 years agoModelsim_Altera error (Memory Allocation Failure)
My design successfully compiled on Quartus II v.11.0 sp1, and i try to simulate it using Modelsim-Altera web free edition 10.0 C. I open a new project (.mpf)on modelsim_ Altera V. 10.C and add the (....
12 years agoWhen you use Altera Starter edition, and trying to compile libraries, very common to get warring like this : Warning: Design size of 0 instances exceeds ModelSim ALTERA recommended capacity. In your case, try to increase the iteration limit (Simulate-Runtime Options) and check it. I had a similar problem with Modelsim 10.c, but you may try also with 6.6d.
If above option is also not working. As tricky said, there might be problem in the design.
