13 years agoModelSim Altera bug in Create Pattern Wizard
I'm trying to use the pattern wizard on modelsim to simulate a simple flip-flop d that i wrote in verilog, i'm following the tutorial on altera.com/literature/ug/ug_gs_msa_qii.pdf and when i click in...
12 years agoSadly I couldn't work with the "Pattern Wizard" in MultiSim, I finally opted to work with TestBenches, the graphical aproach didn't get me anywhere.
I think that I try it in windows XP, and if my memory isn't wrong, it happened the same problem, but it's worth an try. --- Quote Start --- Hi, I have the same problem, did you get any solution since you wrote this post? --- Quote End ---
