20 years agomk_target_board and Quartus/Nios2 ver 5.1 fails
Hi I'm getting script errors when using the mk_target_board util. when using Quartus 5.1 and Nios2 5.1 /cygdrive/c/altera/work/fpga/rev3/oipax_flash_loader
$ mk_target_board --name=T...
20 years agoI'll second the motion by slacker! You WILL get those errors if you don't follow that workaround (it doesn't work out of the box). My problem is that when I do it from the command line as instructed - it gets all the way through erasing and programming, and then the verify fails and the contents of flash are incorrect. Even though I have tested in a program that the flash device works fine as connected.
Let's ponder this one. Altera never once tried it on their own..?? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
