21 years agoMixed source / Assembly listing
Is this possible, so I can get a fair idea on how the code for this is distributed?
0000413c <uart_irq_1>:
413c: 01421204 movi r5,2120
4140: 29000037 ldwio r4,0(r5)
4144: 28000035 stwio zero,0(r5)
4148: 2006d1fa srli r3,r4,7
414c: 1880004c andi r2,r3,1
4150: 10000226 beq r2,zero,415c <uart_irq_1+0x20>
4154: 01821004 movi r6,2112
4158: 30c00037 ldwio r3,0(r6)
415c: 200ed1ba srli r7,r4,6
4160: 3900004c andi r4,r7,1
4164: 20001026 beq r4,zero,41a8 <uart_irq_1+0x6c>
4168: d16003c3 ldbu r5,-32753(gp)
416c: d2200383 ldbu r8,-32754(gp)
4170: 02800034 movhi r10,0
4174: 52840444 addi r10,r10,4113
4178: 2a403fcc andi r9,r5,255
417c: 4a85883a add r2,r9,r10
4180: 4a00062e bgeu r9,r8,419c <uart_irq_1+0x60>
4184: 13400003 ldbu r13,0(r2)
4188: 03021104 movi r12,2116
418c: 63400035 stwio r13,0(r12)
4190: 2ac00044 addi r11,r5,1
4194: d2e003c5 stb r11,-32753(gp)
4198: f800283a ret
419c: 03c02004 movi r15,128
41a0: 03821304 movi r14,2124
41a4: 73c00035 stwio r15,0(r14)
41a8: f800283a ret6 Replies
Hi Jason,
Use the objdump -S option. Regards, --Scott - Altera_Forum
Hi Scott.
It looks as though the -S option is already used: "OBJDUMP = nios2-elf-objdump -D -S -x" in the file C:\altera\kits\nios2_v5\components\altera_nios2\HAL\src\component.mk I suspect I need to turn on a "debug info" option, or to specify the "source dirs" By adding the -l option (line numbers), i.e. "OBJDUMP = nios2-elf-objdump -D -S -x -l" ...I was able to produce a list of line numbers in a few code sections only: e.g. C:\altera\kits\nios2_v5\bin\nios2-gnutools\src\gcc\gcc\config\nios2\lib2-divmod.c - not the HAL nor project source files. So there must be something really simple I've overlooked...... - Altera_Forum
Ahaa!
The mixed source appears in the DEBUG configuration, but not in the RELEASE. - Altera_Forum
Hi Jason,
Yep, you need to make sure the -g option is passed to the compiler. And don't strip the elf ;-) Regards, --Scott - Altera_Forum
Hey,Scott!
I have a question maybe seems silly to you.You said mixed listing can be seen by using the objdump -s option, but where can I set this option in NiosII IDE? Thx - Altera_Forum
Hi yancharles,
> where can I set this option in NiosII IDE? I don't think I can help you with this one since I'm an old command-line fogey ;-) and I always run objdump from the shell. You should however enable debugging information using the '-g' option. You can do this in your project properties under C/C++ Build, Debug level. Regards, --Scott
