13 years agomissing vertical sync signal on clocked video output Core
The video IP core I am working on is working. But there is one problem, the output vertical sync signal is missing from clocked video output Core. Please help me to find what is the rea...
13 years agoIf you don't get any answer from the forum, it probably means that no one else ran into that problem before or has an idea about what the problem could be. If you want official support or answer from Altera you should use mySupport or contact your FAE. On this forum you'll see mostly Altera users.
