13 years agomissing vertical sync signal on clocked video output Core
The video IP core I am working on is working. But there is one problem, the output vertical sync signal is missing from clocked video output Core. Please help me to find what is the rea...
13 years agoaa.. ok i may be giving dumb question but, as i get it you are working on video image , which should give you vertical synchronization signal at a given moment, and the signal is not there? if im correct, please tell us what video format are you using? (pal,secam,ntsc)
