21 years agoMissing Memory
Hi: I've got a Cyclone with NIOS II Quartus 4.1 Attached are 2 SDRAM chips that work great. I nca load the FPGA and then with the IDE load code and step through it. RS232, TImer,...
21 years agoYou should have no problem of coexistance of your dma and your tri-state bridge! At least not from SOPC's point of view. You may run into fitting or timing problems later, but thats a completely different story.
Hoover your cursor on the dots/rings and click them on and off. Thats all you need to setup the bus connections.
