21 years agoMissing Memory
Hi: I've got a Cyclone with NIOS II Quartus 4.1 Attached are 2 SDRAM chips that work great. I nca load the FPGA and then with the IDE load code and step through it. RS232, TImer,...
21 years agoThe CFI flash device needs to be connected to the CPU through an Avalon Tri-State Bridge.
Add an Avalon Tri-State Bridge to your system, connect the avalon_slave port to the cpu and connect the tristate_master port to your flash. -edit- On a second look it seems like you may be doing this. If so, you can ignore me http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Dennis Scott Microtronix Datacom
