Missing Libraries in Nios II Software Build Tools for Eclipse
for one of my University Courses I am doing a Nios II Project on an DE2-115 Development Board from terasIC.
After adding some new Features in the Platform Designer, I found this error while I was debugging the now non working c code:
Can't find a source file at "/build/arc/temp/823101626/ACDS_lwr/ip/sopc/app/gnu/BUILD/gnu/build-newlib.nios2-elf.x86_64-w64-mingw32/nios2-elf/mno-hw-mul/newlib/libc/stdio/../../../../../../src/newlib-2.2/newlib/libc/stdio/printf.c"
I have no idea what to make of it, other than it now misses this file, where it did not before.
My theory is that some dependencies broke, but as to why they did I do not know.
I am using Quartus 18.1 Lite Edition with the Nios II Software Build Tools for Eclipse
Any help would be appreciated. If you need any additional Information let me know
- AnandRaj_S_Intel
Can you run project in normal mode instead of debug mode?
Try by cleaning project, regenerating bsp, build project and check.
Also try by adding source file directory by clicking run as->run configuration->source->add C:\intelFPGA_lite\18.1\nios2eds\bin\gnu\src ->apply-> run
If possible please do attache the project.
The printf.c file should be available in directory C:\intelFPGA_lite\18.0\nios2eds\bin\gnu\src\newlib-2.2\newlib\libc\stdio
And this function can be accessed by adding header stdio.h.
Anand
- JKrek
Sadly this did not work. It made no change at all.
For the Project Code, it is below, but it is kind of a mess, but any attempt to tidy it up is making the Project not working correctly.
#include "system.h" #include <sys/alt_stdio.h> #include <sys/alt_irq.h> #include <unistd.h> #include "altera_avalon_pio_regs.h" #include "altera_up_avalon_audio.h" #include <stdio.h> #include <stdlib.h> #include <unistd.h> #include <string.h> #include <limits.h> #include "altera_up_avalon_character_lcd.h" #include "altera_up_avalon_rs232.h" #define SEC 500000 #define BUF_SIZE 792000 // about 10 seconds of buffer (@ 8K samples/sec) #define BUF_THRESHOLD 96 // 75% of 128 word buffer volatile int * green_LED_ptr = (int *) LED_GREEN_PIO_BASE; volatile int* red_LED_ptr = (int*) LED_RED_PIO_BASE; volatile int* switches = (int*) SW_PIO_BASE; volatile int * audio_ptr = (int *) AUDIO_BASE; volatile int * Recording = (int *) RECORD_PIO_BASE; volatile int * PLAY = (int *) PLAY_PIO_BASE; int fifospace; int record = 0, play = 0, transmit = 0, buffer_index = 0, Seg_com = 0; int buffer_nahm = 0, min, max; int temp; char normalized = 0; alt_16 left_buffer[BUF_SIZE],right_buffer[BUF_SIZE]; alt_8 left_normalized[BUF_SIZE], right_normalized[BUF_SIZE]; alt_up_character_lcd_dev * char_lcd_dev; alt_up_rs232_dev* serialport; unsigned int led_val[19]={0,1,3,7,15,31,63,127,255,511,1023,2047,4095,8191,16383,32767, 65535,131071,262143 }; /* function prototypes */ void check_KEYs(int *, int *, int *, int*); void init_vars(); void writeToLCDAt(int xpos, int ypos, char* text); int test(); void normalize(); enum {KEY_0 = 0x0E, KEY_1 = 0x0D, KEY_2 = 0x0B, KEY_3 = 0x07}; int main(int argc, char **argv) { init_vars(); writeToLCDAt(0,0,"Welcome to "); writeToLCDAt(0,1,"L'Audio Recorder"); while (1) { Seg_com = test(); if (Seg_com == 0) { *(green_LED_ptr) = *(green_LED_ptr) | 1; } if (Seg_com == 1) { *(green_LED_ptr) = 0; } check_KEYs(&record, &play, &transmit, &buffer_index); if (record){ *(green_LED_ptr) = 16; // turn on LEDR[0] fifospace = *(audio_ptr + 1); // read the audio port fifospace register max = 0; min = SHRT_MAX; if ((fifospace & 0x000000FF) > BUF_THRESHOLD) {// check RARC // store data until the the audio-in FIFO is empty or the buffer // is full while ((fifospace & 0x000000FF) && (buffer_index < BUF_SIZE)) { *(Recording) = 1; left_buffer[buffer_index] = *(audio_ptr + 2); *red_LED_ptr=led_val[(abs(left_buffer[buffer_index])) *(18) /(SHRT_MAX)]; right_buffer[buffer_index] = *(audio_ptr + 3); ++buffer_index; if(left_buffer[buffer_index] > max){max = left_buffer[buffer_index];}else if(left_buffer[buffer_index] < min){min = left_buffer[buffer_index];} // printf("index: %d name: %d",buffer_index,buffer_nahm); if (buffer_index == BUF_SIZE || (KEY_0 == *((int*) BTN_PIO_BASE))) {// done recording usleep(SEC/2); *(Recording) = 0; record = 0; normalized = 0; *(green_LED_ptr) = 0x0; // turn off LEDR temp = buffer_index; } fifospace = *(audio_ptr + 1); // read the audio port fifospace register } } } else if (play) { *(green_LED_ptr) = 64; // turn on LEDR_1 fifospace = *(audio_ptr + 1); // read the audio port fifospace register if ((fifospace & 0x00FF0000) > BUF_THRESHOLD) // check WSRC { // output data until the buffer is empty or the audio-out FIFO // is full while ((fifospace & 0x00FF0000) && (buffer_index < BUF_SIZE)) { *(PLAY) = 1; *(audio_ptr + 2) =( left_buffer[buffer_index]); if(buffer_index %256 == 0){ *red_LED_ptr=led_val[left_normalized[buffer_index]]; } *(audio_ptr + 3) = (right_buffer[buffer_index]); //alt_up_rs232_write_data(serialport, left_buffer[buffer_index] & 0x00FF); //alt_up_rs232_write_data(serialport, (left_buffer[buffer_index] & 0xFF00) >> 8); ++buffer_index; if (buffer_index == temp || (KEY_0 == *((int*) BTN_PIO_BASE))){// done playback play = 0; *(PLAY) = 0; *(green_LED_ptr) = 0x0; // turn off LEDR } fifospace = *(audio_ptr + 1); // read the audio port fifospace register } } } else if (transmit) { buffer_index = 0; while (buffer_index < 16000 || buffer_index <= temp) { if (alt_up_rs232_get_available_space_in_write_FIFO(serialport) > 2) { alt_up_rs232_write_data(serialport, left_buffer[buffer_index] & 0x00FF); alt_up_rs232_write_data(serialport, (left_buffer[buffer_index] & 0xFF00) >> 8); ++buffer_index; } } transmit = 0; } else if (record == 0 && play == 0 && transmit == 0) { *(PLAY) = 0; *(Recording) = 0; if(normalized == 0) normalize(); *red_LED_ptr = 0x0; writeToLCDAt(0,0,"Standby "); } } } void check_KEYs(int* KEY0, int* KEY1, int* KEY2, int* buffer) { // read the pushbutton KEY values int* BTN_ptr = (int*)BTN_PIO_BASE; if (*(BTN_ptr) == KEY_2) { usleep(SEC); printf("RECORDING START \n"); writeToLCDAt(0,0,"RECORDING "); *buffer = 0; // clear audio-in FIFO *(audio_ptr) = 0x4; *(audio_ptr) = 0x0; *KEY0 = 1; } else if (*(BTN_ptr) == KEY_3) { usleep(SEC); printf("Playback soll abgespielt werden \n"); writeToLCDAt(0,0,"PLAYING "); *buffer = 0; // clear audio-out FIFO *(audio_ptr) = 0x8; *(audio_ptr) = 0x0; *KEY1 = 1; } else if (*(BTN_ptr) == KEY_1 ) { usleep(SEC); writeToLCDAt(0,0,"TRANSMITTING "); printf("Start Transmission!\n"); *buffer = 0; *KEY2 = 1; } } int test() { int Seg_value; volatile int * Seg_ptr = (int *) SEG_COM_BASE; Seg_value = *(Seg_ptr); return Seg_value; } void init_vars(){ *green_LED_ptr = 0x0; *red_LED_ptr =0x0; printf("%d", *switches>>1); char_lcd_dev = alt_up_character_lcd_open_dev(CHARACTER_LCD_NAME); if (char_lcd_dev == NULL){ alt_printf("Error: could not open character LCD device\n"); }else{ alt_printf("Opened character LCD device\n"); alt_up_character_lcd_init(char_lcd_dev); } serialport = alt_up_rs232_open_dev(RS232_UART_NAME); if (serialport == NULL){ alt_printf("Error: could not open serialport device\n"); }else{ alt_printf("Opened serialport device\n"); /*char teststring[] = "Hello World!"; for (int i = 0; i <= strlen(teststring); ++i) { alt_up_rs232_write_data(serialport, teststring[i]); }*/ } printf("Initialisierung fertig !\n"); } void writeToLCDAt(int x_pos, int y_pos, char* text){ alt_up_character_lcd_set_cursor_pos(char_lcd_dev, x_pos, y_pos); alt_up_character_lcd_string(char_lcd_dev,text); } void minmax(int* min, int* max){ *max = *min = left_buffer[0]; for (int i = 1; i < temp;i++ ){ if(left_buffer[i] > *max){ *max = abs(left_buffer[i]); }else if (left_buffer[i] < *min){ *min = abs(left_buffer[i]); } } } void normalize(){ writeToLCDAt(0,0,"Normalizing "); printf("min: %d, max: %d", min, max); for(int i = 0;i<temp;i++ ){ left_normalized[i]=(((abs(left_buffer[i])- min) *(18) /(max - min))); //printf("%d\n",left_normalized[i]); } normalized = 1; }Thank you for your help so far, if you need anything else, let me know.
Jan
- AnandRaj_S_Intel
Thanks jan,
Can you also attache the .qar file, Click on the Project menu -> Archive Project
