JKrek
7 years agoMissing Libraries in Nios II Software Build Tools for Eclipse
Hello, for one of my University Courses I am doing a Nios II Project on an DE2-115 Development Board from terasIC. After adding some new Features in the Platform Designer, I found this error while ...
JKrek
7 years agoSadly this did not work. It made no change at all.
For the Project Code, it is below, but it is kind of a mess, but any attempt to tidy it up is making the Project not working correctly.
#include "system.h"
#include <sys/alt_stdio.h>
#include <sys/alt_irq.h>
#include <unistd.h>
#include "altera_avalon_pio_regs.h"
#include "altera_up_avalon_audio.h"
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <limits.h>
#include "altera_up_avalon_character_lcd.h"
#include "altera_up_avalon_rs232.h"
#define SEC 500000
#define BUF_SIZE 792000 // about 10 seconds of buffer (@ 8K samples/sec)
#define BUF_THRESHOLD 96 // 75% of 128 word buffer
volatile int * green_LED_ptr = (int *) LED_GREEN_PIO_BASE;
volatile int* red_LED_ptr = (int*) LED_RED_PIO_BASE;
volatile int* switches = (int*) SW_PIO_BASE;
volatile int * audio_ptr = (int *) AUDIO_BASE;
volatile int * Recording = (int *) RECORD_PIO_BASE;
volatile int * PLAY = (int *) PLAY_PIO_BASE;
int fifospace;
int record = 0, play = 0, transmit = 0, buffer_index = 0, Seg_com = 0;
int buffer_nahm = 0, min, max;
int temp;
char normalized = 0;
alt_16 left_buffer[BUF_SIZE],right_buffer[BUF_SIZE];
alt_8 left_normalized[BUF_SIZE], right_normalized[BUF_SIZE];
alt_up_character_lcd_dev * char_lcd_dev;
alt_up_rs232_dev* serialport;
unsigned int led_val[19]={0,1,3,7,15,31,63,127,255,511,1023,2047,4095,8191,16383,32767, 65535,131071,262143 };
/* function prototypes */
void check_KEYs(int *, int *, int *, int*);
void init_vars();
void writeToLCDAt(int xpos, int ypos, char* text);
int test();
void normalize();
enum {KEY_0 = 0x0E, KEY_1 = 0x0D, KEY_2 = 0x0B, KEY_3 = 0x07};
int main(int argc, char **argv) {
init_vars();
writeToLCDAt(0,0,"Welcome to ");
writeToLCDAt(0,1,"L'Audio Recorder");
while (1) {
Seg_com = test();
if (Seg_com == 0) {
*(green_LED_ptr) = *(green_LED_ptr) | 1;
if (Seg_com == 1) {
*(green_LED_ptr) = 0;
check_KEYs(&record, &play, &transmit, &buffer_index);
if (record){
*(green_LED_ptr) = 16; // turn on LEDR[0]
fifospace = *(audio_ptr + 1); // read the audio port fifospace register
max = 0; min = SHRT_MAX;
if ((fifospace & 0x000000FF) > BUF_THRESHOLD) {// check RARC
// store data until the the audio-in FIFO is empty or the buffer
// is full
while ((fifospace & 0x000000FF) && (buffer_index < BUF_SIZE)) {
*(Recording) = 1;
left_buffer[buffer_index] = *(audio_ptr + 2);
*red_LED_ptr=led_val[(abs(left_buffer[buffer_index])) *(18) /(SHRT_MAX)];
right_buffer[buffer_index] = *(audio_ptr + 3);
++buffer_index;
if(left_buffer[buffer_index] > max){max = left_buffer[buffer_index];}else if(left_buffer[buffer_index] < min){min = left_buffer[buffer_index];}
// printf("index: %d name: %d",buffer_index,buffer_nahm);
if (buffer_index == BUF_SIZE || (KEY_0 == *((int*) BTN_PIO_BASE))) {// done recording
usleep(SEC/2);
*(Recording) = 0;
record = 0;
normalized = 0;
*(green_LED_ptr) = 0x0; // turn off LEDR
temp = buffer_index;
} else if (play) {
*(green_LED_ptr) = 64; // turn on LEDR_1
if ((fifospace & 0x00FF0000) > BUF_THRESHOLD) // check WSRC
// output data until the buffer is empty or the audio-out FIFO
// is full
while ((fifospace & 0x00FF0000) && (buffer_index < BUF_SIZE)) {
*(PLAY) = 1;
*(audio_ptr + 2) =( left_buffer[buffer_index]);
if(buffer_index %256 == 0){
*red_LED_ptr=led_val[left_normalized[buffer_index]];
*(audio_ptr + 3) = (right_buffer[buffer_index]);
//alt_up_rs232_write_data(serialport, left_buffer[buffer_index] & 0x00FF);
//alt_up_rs232_write_data(serialport, (left_buffer[buffer_index] & 0xFF00) >> 8);
++buffer_index;
if (buffer_index == temp || (KEY_0 == *((int*) BTN_PIO_BASE))){// done playback
play = 0;
*(PLAY) = 0;
} else if (transmit) {
buffer_index = 0;
while (buffer_index < 16000 || buffer_index <= temp) {
if (alt_up_rs232_get_available_space_in_write_FIFO(serialport) > 2) {
++buffer_index;
transmit = 0;
} else if (record == 0 && play == 0 && transmit == 0) {
*(PLAY) = 0;
*(Recording) = 0;
if(normalized == 0) normalize();
*red_LED_ptr = 0x0;
writeToLCDAt(0,0,"Standby ");
void check_KEYs(int* KEY0, int* KEY1, int* KEY2, int* buffer) {
// read the pushbutton KEY values
int* BTN_ptr = (int*)BTN_PIO_BASE;
if (*(BTN_ptr) == KEY_2) {
usleep(SEC);
printf("RECORDING START \n");
writeToLCDAt(0,0,"RECORDING ");
*buffer = 0;
// clear audio-in FIFO
*(audio_ptr) = 0x4;
*(audio_ptr) = 0x0;
*KEY0 = 1;
} else if (*(BTN_ptr) == KEY_3) {
usleep(SEC);
printf("Playback soll abgespielt werden \n");
writeToLCDAt(0,0,"PLAYING ");
*buffer = 0;
// clear audio-out FIFO
*(audio_ptr) = 0x8;
*(audio_ptr) = 0x0;
*KEY1 = 1;
} else if (*(BTN_ptr) == KEY_1 ) {
usleep(SEC);
writeToLCDAt(0,0,"TRANSMITTING ");
printf("Start Transmission!\n");
*buffer = 0;
*KEY2 = 1;
int test() {
int Seg_value;
volatile int * Seg_ptr = (int *) SEG_COM_BASE;
Seg_value = *(Seg_ptr);
return Seg_value;
void init_vars(){
*green_LED_ptr = 0x0;
*red_LED_ptr =0x0;
printf("%d", *switches>>1);
char_lcd_dev = alt_up_character_lcd_open_dev(CHARACTER_LCD_NAME);
if (char_lcd_dev == NULL){
alt_printf("Error: could not open character LCD device\n");
}else{
alt_printf("Opened character LCD device\n");
alt_up_character_lcd_init(char_lcd_dev);
serialport = alt_up_rs232_open_dev(RS232_UART_NAME);
if (serialport == NULL){
alt_printf("Error: could not open serialport device\n");
}else{
alt_printf("Opened serialport device\n");
/*char teststring[] = "Hello World!";
for (int i = 0; i <= strlen(teststring); ++i) {
alt_up_rs232_write_data(serialport, teststring[i]);
printf("Initialisierung fertig !\n");
void writeToLCDAt(int x_pos, int y_pos, char* text){
alt_up_character_lcd_set_cursor_pos(char_lcd_dev, x_pos, y_pos);
alt_up_character_lcd_string(char_lcd_dev,text);
void minmax(int* min, int* max){
*max = *min = left_buffer[0];
for (int i = 1; i < temp;i++ ){
if(left_buffer[i] > *max){
*max = abs(left_buffer[i]);
}else if (left_buffer[i] < *min){
*min = abs(left_buffer[i]);
void normalize(){
writeToLCDAt(0,0,"Normalizing ");
printf("min: %d, max: %d", min, max);
for(int i = 0;i<temp;i++ ){
left_normalized[i]=(((abs(left_buffer[i])- min) *(18) /(max - min)));
//printf("%d\n",left_normalized[i]);
normalized = 1;
}Thank you for your help so far, if you need anything else, let me know.
Jan
AnandRaj_S_Intel
7 years agoThanks jan,
Can you also attache the .qar file, Click on the Project menu -> Archive Project
