missing iniche on 21.4
just installed quartus v21.4 and i can't find the altera_iniche folder.
i used to have it on v18.1.
was it replaced?
thanx
- ShengN_altera
The deliverable for NicheStack TCP/IP Stack used in Nios® II applications is discontinued starting with Intel® Quartus® Prime Standard Software version 21.1 and Intel® Quartus® Prime Pro Software version 21.3.
That's why you can't find the altera_iniche folder. May check on these two KDB links below.
https://www.intel.com/content/www/us/en/support/programmable/articles/000087872.html
https://www.intel.com/content/www/us/en/support/programmable/articles/000087469.html
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
- windya
what is the current alternative?
was the new tcp/ip stack already implemented?
thanx
- ShengN_altera
New Nios® V Processor Features and Enhancements
- Enhanced Nios® V/m processor with µC/TCP-IP stack support, including two new example designs that demonstrate the use of this stack.
I think this must be something you are looking for. Implemented starting with version 22.1. May check out these links below:
https://community.intel.com/t5/Intel-SoC-FPGA-Embedded/TCP-IP-stack/m-p/1345202
Sheng
- ShengN_altera
Do you have any further update or Should I consider that case to be closed?
Sheng
- ShengN_altera
Since there are no further feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you.
