16 years agoMinimal MMU linux hangs on DE1 board
Hi all, when trying to build my first MMU linux on a DE1 board system hangs just after nios2-terminal with: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-term...
14 years ago --- Quote Start --- Not sure you want a print call in that loop! I'd expect r2 to have the value 32 (line size) r0 initialised to some cache address. r1 initialised to r2 + cache size. --- Quote End --- Hi , I am following the steps for compiling the linux as explained in the below address, http://www.alterawiki.com/wiki/uclinuxdist But the uclinux hangs after uncompressing , on the console i get Uncompressing linux ... Ok booting kernel , and stops here. I have attached sopcinfo, ptf and sof file . Can u help me is there any problem in the design. Regards, Tejeshwar K
