20 years agoMini howto build toolschain and initramfs on Linux
UPDATE : This post is out of date. Please follow the new one, http://forum.niosforum.com/forum/ind...showtopic=3174 This is a mini howto about building toolchains ,uClinux and initramfs for NIOS2 o...
20 years agoI have met the same problem like mountain8848.so unlucky!
slackware 9.0,gcc 3.2.2 --- Quote Start --- I got some errors when build the cross tool chain 2. ================================================== windows_src: binutils->error gcc->ok elf2flt->ok here is the gcc error...
checking whether ANSI C string concatenation works ... yes
*** ld does not support target nios2-elf
*** see ld/configure.tgt for supported targets
make: *** Error 1
