20 years agoMini howto build toolschain and initramfs on Linux
UPDATE : This post is out of date. Please follow the new one, http://forum.niosforum.com/forum/ind...showtopic=3174 This is a mini howto about building toolchains ,uClinux and initramfs for NIOS2 o...
20 years agofrist, make sure you have the compiler build,
$ nios2-elf-gcc -v
Reading specs from /usr/local/lib/gcc/nios2-elf/3.4.1/specs
Configured with: ../../gcc/configure --target=nios2-elf --enable-languages=c
Thread model: single
gcc version 3.4.1 (Altera Nios II 5.1 b73) then, the hardware include header generation. note, this is a signle line command. make ARCH=nios2nommu O=/usr/local/src/nios2/build/kernel CROSS_COMPILE=nios2-elf- hwselect SYSPTF=/usr/local/src/nios2/build/yoursystem.ptf next the config, note, this is a signle line command. make ARCH=nios2nommu O=/usr/local/src/nios2/build/kernel CROSS_COMPILE=nios2-elf- menuconfig next, the compile, note, this is a signle line command. make ARCH=nios2nommu O=/usr/local/src/nios2/build/kernel CROSS_COMPILE=nios2-elf-
