20 years agoMini howto build toolschain and initramfs on Linux
UPDATE : This post is out of date. Please follow the new one, http://forum.niosforum.com/forum/ind...showtopic=3174 This is a mini howto about building toolchains ,uClinux and initramfs for NIOS2 o...
20 years agoI could only agree that MMU makes the different.
Again the patch to support minx in unified diff. linux-2.6.x/include/asm-nios2nommu/bitops.h--- bitops.h 2005/11/10 06:55:12 1.1
+++ bitops.h 2005/11/10 06:56:58
@@ -469,4 +469,11 @@
# define ext2_find_first_zero_bit find_first_zero_bit
# define ext2_find_next_zero_bit find_next_zero_bit
+/* Bitmap functions for the minix filesystem. */
+#define minix_test_and_set_bit(nr,addr) test_and_set_bit(nr,addr)
+#define minix_set_bit(nr,addr) set_bit(nr,addr)
+#define minix_test_and_clear_bit(nr,addr) test_and_clear_bit(nr,addr)
+#define minix_test_bit(nr,addr) test_bit(nr,addr)
+#define minix_find_first_zero_bit(addr,size) find_first_zero_bit(addr,size)
# endif /* _ASM_NIOS_BITOPS_H */ About the busybox, you can also use the stable release 1.01. http://busybox.net/downloads/busybox-1.01.tar.bz2 (http://busybox.net/downloads/busybox-1.01.tar.bz2) With the patch. --- modutils/insmod.c 2005/12/28 11:32:46 1.1
+++ modutils/insmod.c 2005/12/28 11:33:20
@@ -4022,7 +4022,7 @@
fstat(fd, &st);
len = st.st_size;
- map = mmap(NULL, len, PROT_READ, MAP_SHARED, fd, 0);
+ map = mmap(NULL, len, PROT_READ, MAP_PRIVATE, fd, 0);
if (map == MAP_FAILED) {
bb_perror_msg_and_die("cannot mmap `%s'", filename);
--- Makefile 2005/12/28 09:14:17 1.1
+++ Makefile 2005/12/28 13:16:09
@@ -123,9 +123,18 @@
include $(patsubst %,%/Makefile.in, $(SRC_DIRS))
-include $(top_builddir)/.depend
-busybox: $(ALL_MAKEFILES) .depend include/config.h $(libraries-y)
+busybox: busybox.elf
+ $(APP_PLUGIN)/bin/elf2flt -s 16000 -o $@ $<
+# Make a relocatable ELF file.
+%.elf : %.bin
+ $(LD) -T $(APP_PLUGIN)/scripts/elf2flt.ld -Ur -o $@ $<
+busybox.bin: $(ALL_MAKEFILES) .depend include/config.h $(libraries-y)
$(CC) $(LDFLAGS) -o $@ -Wl,--start-group $(libraries-y) $(LIBRARIES) -Wl,--end-group
- $(STRIPCMD) $@
+# $(STRIPCMD) $@
busybox.links: $(top_srcdir)/applets/busybox.mkll include/config.h $(top_srcdir)/include/applets.h
- $(SHELL) $^ >$@
@@ -272,7 +281,7 @@
docs/busybox pod2htm* *.gdb *.elf *~ core .*config.log
docs/BusyBox.txt docs/BusyBox.1 docs/BusyBox.html
docs/busybox.net/BusyBox.html busybox.links libbb/loop.h
- .config.old .hdepend busybox
+ .config.old .hdepend busybox *.bin
- rm -rf _install
- find . -name .\*.flags -exec rm -f {} \;
- find . -name \*.o -exec rm -f {} \;
--- Rules.mak 2005/12/28 09:17:00 1.1
+++ Rules.mak 2005/12/28 13:34:54
@@ -71,12 +71,13 @@
# If you are using Red Hat 6.x with the compatible RPMs (for developing under
# Red Hat 5.x and glibc 2.0) uncomment the following. Be sure to read about
# using the compatible RPMs (compat-*) at http://www.redhat.com !
-#LIBCDIR:=/usr/i386-glibc20-linux
+LIBCDIR?=$(UCLIBC_PLUGIN)
+KERNEL_INCLUDE=$(shell echo $(KERNEL_BUILD_DIRECTORY))/include
# For other libraries, you are on your own. But these may (or may not) help...
-#LDFLAGS+=-nostdlib
-#LIBRARIES:=$(LIBCDIR)/lib/libc.a -lgcc
-#CROSS_CFLAGS+=-nostdinc -I$(LIBCDIR)/include -I$(GCCINCDIR)
+LDFLAGS+=-nostdlib -Wl,-r -Wl,-d -L$(LIBCDIR)/lib $(LIBCDIR)/lib/crt0.o
+LIBRARIES:=$(LIBCDIR)/lib/libc.a -lgcc
+CROSS_CFLAGS+=-nostdinc -I$(LIBCDIR)/include -I$(KERNEL_INCLUDE) -funsigned-char -iwithprefix include -D__uClinux__
# GCCINCDIR:=$(shell gcc -print-search-dirs | sed -ne "s/install: \(.*\)/\1include/gp")
WARNINGS=-Wall -Wstrict-prototypes -Wshadow
@@ -96,6 +97,7 @@
-e 's/sh/sh/'
-e 's/mips-.*/mips/'
-e 's/mipsel-.*/mipsel/'
+ -e 's/nios2-.*/nios2nommu/'
-e 's/cris.*/cris/'
endif Or use the snapshot. http://busybox.net/downloads/busybox-snapshot.tar.bz2 (http://busybox.net/downloads/busybox-snapshot.tar.bz2) With the patch. --- Makefile 2005/12/27 13:07:23 1.1
+++ Makefile 2005/12/28 14:52:08
@@ -211,9 +211,18 @@
endif# ifneq ($(strip $(HAVE_DOT_CONFIG)),y)
-busybox: .depend $(libraries-y)
+%.elf : %.bin
+busybox.bin: .depend $(libraries-y)
$(CC) $(EXTRA_CFLAGS) $(LDFLAGS) -o $@ -Wl,--start-group $(libraries-y) $(LIBRARIES) -Wl,--end-group
- $(STRIPCMD) $@
+# $(STRIPCMD) $@
busybox.links: $(top_srcdir)/applets/busybox.mkll include/bb_config.h $(top_srcdir)/include/applets.h
- $(SHELL) $^ >$@
@@ -328,7 +337,7 @@
- .config.old busybox
+ .config.old busybox *.bin
- rm -rf _install testsuite/links
--- Rules.mak 2005/12/27 12:56:02 1.1
+++ Rules.mak 2005/12/28 14:53:39
@@ -72,12 +72,13 @@
-#CROSS_CFLAGS+=-nostdinc -I$(LIBCDIR)/include -I$(GCCINCDIR) -funsigned-char
@@ -103,6 +104,7 @@
-e 's/sh/sh/'
-e 's/cris.*/cris/'
endif The .config must has, ## Build Options#
CONFIG_STATIC=y
CONFIG_LFS=y
USING_CROSS_COMPILER=y
CROSS_COMPILER_PREFIX="nios2-elf-"
EXTRA_CFLAGS_OPTIONS="-Dfork=vfork"
# # Installation Options# # CONFIG_INSTALL_NO_USR is not set
PREFIX="/usr/local/src/nios2/build/rootfs" Then build, make UCLIBC_PLUGIN=/usr/local/nios2-elf APP_PLUGIN=/usr/local/nios2-elf KERNEL_BUILD_DIRECTORY=/usr/local/src/nios2/build/kernel menuconfig
make UCLIBC_PLUGIN=/usr/local/nios2-elf APP_PLUGIN=/usr/local/nios2-elf KERNEL_BUILD_DIRECTORY=/usr/local/src/nios2/build/kernel install
