13 years agoMigration Error from NIOS 11.2 to NIOS 12.1
After rebuilding my project after a long pause I discovered a building error in NIOS that seems to be related to the update from NIOS 11.2 to NIOS 12.1: Description Resource Path Loc...
13 years agoThis issue is probably solved.
I created a new "NIOS II Application and BSP from Template" using the updated NIOS II and then moved all previously created .c/.h files to the new created project.
