19 years agoMif file Simulation in modelsim using nios IDE
My core contains ROM (mif) file. I want to simulate it in modelsim software using Nios IDE. But Modelsim does not support mif file. Please give some idea to solve this problem.1 Reply
--- Quote Start --- originally posted by slsnios@Nov 23 2006, 10:04 AM hi,my core contains rom (mif) file. i want to simulate it in modelsim software using nios ide. but modelsim does not support mif file.
please give some idea to solve this problem.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19587)
--- quote end ---
--- Quote End --- if you use the Nios IDE, coud didn't need mif files. The Nios IDE generate an elf-file after compilation. Now you can start ModelSim simulation and the NIOS IDE generate an dat-file with your program and your data. An other way, you can convert your files in Quartus II. On the Altera HP is a video over "How I simulate the Nios core with ModelSim!".
