20 years agoMicrotronix uKIT FLASH Programming problem
Hi all,
I have made a NIOS I project for the Microtronix uKIT development board. All the hardware and software stuff is running but I have a big problem. I am storing the fpga design dat in the epcs device and I want to start the software from FLASH (CFI for AM29LV640MH). But I cannot bring the software into the FLASH. I use also the old toolchain: nios-build (make) --> srec2flash --> nios-run *.flash I can observe that the erasing of the FLASH sectors operates properly but when it starts to write something to the FLASH, the processor hangs up. With a NIOS II design the FLASH programming of some test programs (e.g. mem_test) works properly. I know, the uKIT was mainly developed for NIOS II but I have to make a system, that is more or less equal to some former designs. This former designes used NIOS I and since I wanted to use the software without major changes from the old design I decided to use the NIOS I here too. Is there a known problem with NIOS I the CFI and the old GERMS monitor? Is there any chance to put my software into the flash using a NIOS II - "PROGRAMMER" - system? Looking forward for some replies... Marco.No RepliesBe the first to reply
