22 years agoMicroC/OS-II Problems
I have a Nios II project that is using MicroC/OS-II. This is the one that comes with the Nios II, not the Microtronix port for the Nios 1. So far I have just been using the default settings, but I ...
21 years agoThe problem is that in system.h, the# defines for the OS bits still get generated with the "s around them. I just installed Quartus 4.2 and NiosII 1.1 yesterday and it still does it. I completely removed the older versions of Quartus and Nios and I removed the Release and Debug directories. Any ideas? The fix is to just remove the "s like you stated months ago. You now say that it should be fixed. Hmmm.
